Strict Standards: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EST/-5.0/no DST' instead in /homepages/17/d101900905/htdocs/illtuned/forum/viewtopic.php on line 988
Strict Standards: getdate(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EST/-5.0/no DST' instead in /homepages/17/d101900905/htdocs/illtuned/forum/viewtopic.php on line 988
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4284: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4286: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4287: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4288: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
illtuned.com / FJORC.org • View topic - FJ Cruiser / GSJ15 / 'mini tank'
Postby Admin » Sat Apr 24, 2010 10:07 am
2008 Sandstorm FJ Cruiser (GSJ15)
( ^^ in this pic - BajaRack, LightForce 170 Striker and Toyota Off-Road pkg. wheels on Yokohama 33" Geolander M/T+)
Image Image
Image Image
Special thanks to Yokohama, BajaRack, Man-A-Fre, LightForce & BudBuilt!
Exterior Armor
* BudBuilt 5 pc. Skid Plate Set
* BudBuilt Rear Diff Armor! (SS)*
* Toyota OE Rock Rails --> 4+Plus (MAF) Rock Sliders*
* 4+Plus Rear Lower Shock Skid
* Expedition One Front Bumper
* Kaymar Dual Pivot Tow Bumper
Drivetrain & Traction Aids
* ARB Air Locker (Front, RD111)
* Toyota OE Rear Differential E-Locker
* Toyota Active Traction (A-Trac)
* Nitro 4.88 gears
Suspension
* OME 886/896 (front/rear springs)
* OME Nitrochargers N140 (Front)
* OME Long Travel Remote (LTR) (Rear)
**Long Travel Man-A-Fre Setup**
* 4+Plus Front Upper Control Arms
* 4+Plus High Angle Super HD Rear Lower Control Arms
* 4+Plus High Angle Super HD Rear Upper Control Arms
* 4+Plus High Angle Super HD Panhard Bar
* 4+Plus Extended Brake Lines
Wheel & Tire
* (TRD) Trail Teams wheels, Matte Black 16x7.5
* Yokohama 315/75-16 (35") Geolandar M/T +
* SpiderTrax 1.25" wheel spacers
Lighting
* LightForce Striker 170 mounted to the front bumper
* SilverStar Ultra head lights replacement lamps
Interior
* ARB Freezer / Fridge ("jr.")
* Belkin 300w Power Inverter
* Toyota OE Psg. armrest
* Toyota OE Cargo nets
* Toyota 5 pc. All-Weather mats
* ScanGauge II with XGauge
* MPAC / Springtail Solutions Side Rack
* MPAC / Springtail Solutions Rear Rack
* MPAC / Springtail Solutions Velcro Med Pack
* Various MOLLE & ALICE Bags
Trail Gear
* Superwinch EPi9000 (Amsteel Blue Syn. Line)
* Superwinch Aluminum Hawse fairlead
* Hi-Lift (custom 46") Jack, ORK, ORB, Wabfab adapter & Daystar Isolator
* Tow Straps & D-Shackles
* ARB EZ Tire Deflator
* ARB High Output Air Compressor
* Superflow MV50 Air Compressor (backup)
* Cobra 75, Firestik and Bandi Mount
* BajaRack w/ Hi-lift, Shovel/ax and light mounts
* BajaRack Ladder*
* Powertank 10# CO2 tank w/ adj. regulator
* Staun Tyre Deflators
* ARB Tire Inflator Kit
Miscellaneous
* Safari Snorkel (#415 for Off-Road Pkg. FJ)
* OE Fender flares removed
* Modified OEM Tailpipe ;)
* Toyota 4WD Magazine
* Overland Journal
* Military S-502 custom 'Expedition Trailer' featuring:
Full ac & heat with power inversion - BajaRack Expedition Rack with LightForce - 140 Striker Lights - Camping Lab RTT (roof top tent), Camping Lab Awning with two rooms (changing and rest - Pelican 0350 Cube for extra trail gear.
Wish List
Admin
Site Admin
Hillsville - Sand Dunes
Postby Chris » Tue Apr 27, 2010 10:36 pm
Hillsville - Shehan's Trail & Misc.
Postby Chris » Tue Apr 27, 2010 11:56 pm
bearing, starter, flares and more!
Postby Chris » Wed May 12, 2010 12:23 am
FJ is up on the rack waiting for a wheel bearing.. first one that has went sent new. Can't complain. The starter is def. going to need a good cleaning again.. may be time to replace in the near future.
The OE fender flares finally "fell off"..
Rock Crawler wheel (extra one I bought earlier this year) is being test fit.. looks great but will need to shave the caliper if I'm going to use them without a spacer. Just needs a few mm. I really love a white wheel on the FJC. I still may get a set of these dedicated to the FJ.. I originally bought six of them for the FJ, but then bought the Hilux and figured I may as well use them on it.. Now they have found there way on the 80 series..
Hrmm.. what I should do it rock some 37's on an extra set of wheels and share them with the FJ from time to time..
8-) Ah, common bolt patters are great... I never have to buy a set of tires for any one vehicle! :slap:
Re: FJ Cruiser / GSJ15 / 'mini tank'
Postby Chris » Tue Jun 01, 2010 10:44 am
Sale on Rock Crawler wheels.. I just may pick up a few more and put them on the FJ...
If anyone is looking for steel wheels- the price is good right now.
Postby Chris » Tue Jun 08, 2010 4:51 am
money pit goodness.. ^
Postby HyperBuzzin » Tue Jun 08, 2010 9:43 am
There ya go, Chris!!
A LOT more water out there than the last time I was there with ya!!
Hyperbuzzin..... „ɹǝʇʇods ʎɯ ǝɯɐןq ˙˙˙˙sıɥʇ pɐǝɹ uɐɔ noʎ ɟı„
His: '04 Jeep TJ Unlimited: 2.25"BB--Super Swampers-- BDS Disco's
Hers: '06 Jeep KJ: Stock (for now?)
Also for on the trails, '01 KLX 300R
And also for the street, '99 Vulcan 750
HyperBuzzin
FJORC Officer
videos
Postby Chris » Tue Jun 08, 2010 6:38 pm
Ryan... testing his ability to not drop himself and his camera into the muddy waters... Hey, someone has to get the footage..
Postby Chris » Thu Jul 29, 2010 12:04 am
fixed the belt and pulley and then watched my power steering pump fail..........
rebuild kit will be here in a few days.. silly ps pump seal..
Postby Chris » Tue Aug 17, 2010 9:32 am
Ended up getting a used Power Steering pump as well. Figure I'll throw it on and keep the other one for a spare.
Going to fix it soon and also finally install the MAF rock rails for Rausch creek I4WDTA training fun.
Next
Return to Truck
Users browsing this forum: No registered users and 0 guests
cron
