Strict Standards: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EST/-5.0/no DST' instead in /homepages/17/d101900905/htdocs/illtuned/forum/viewtopic.php on line 988
Strict Standards: getdate(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EST/-5.0/no DST' instead in /homepages/17/d101900905/htdocs/illtuned/forum/viewtopic.php on line 988
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4284: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4286: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4287: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4288: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
illtuned.com / FJORC.org • View topic - Hilux / 3rd gen 4x4 / 'Red'
Gone but not forgotten!
Postby Admin » Tue Jun 08, 2010 2:37 am
1992 トヨタ Hilux
Red will be an illtuned Garage vehicle that either get transformed into an exo-caged full body truck or a flat bed style truggy. The platform brings a good bit of potential to the table. This one is coming with a bunch of modifications. Some will stay, some will go-
Wheels and tires are Super Swamper TSL's (36x12.50") on 15x8" aluminum wheels. 5.29 gears and a Supra LSD up front; welded rear setup. Front and rear bumpers will be "massaged".. and the cheap winch will stay on until a Superwinch is needed.
Red, isn't about being pretty... it isn't about looking clean, ever. ;) Shouldn't be too hard to keep that idea going.. :lol:
In short. Red is here so that 'Blue' doesn't have to be destroyed and beat on. (too much)
*Red is also nick named Red because my good friend "Red" will be wheeling it from time to time.
*Red is also known as/spelled Redd. For my man Redd Foxx. "You big dummy!"
Drivetrain
Solid axle swap from ('85) 2nd gen Hilux :cheer:
5.29 gears with Supra LSD front and welded rear :o
22-RE 2.4 Inline four, stock
Suspension
4" All Pro leafs
3" Body lift
shock hoops with 12" Rancho shocks up front
Pro comp shocks in the rear
Wheels & Tires
Interco Super Swamper TSL (36x12.50-15) :band:
Aluminum 15x8 wheels (more info to come)
Misc.
Internal roll cage
cheap winch (9,000 lb) (tested, it works - bonus!)
cheap custom front and rear bumpers
Admin
Site Admin
Re: Hilux / 3rd gen 4x4 / 'Red'
Postby Lumpy » Wed Jun 09, 2010 4:57 pm
Not a bad looking machine there man!!! :band:
92 Toyota Pickup
22re 268 cam 5spd
31x10.50
Rest stock for...now
95 4Runner
3.slow auto
(5spd someday, I have a donor truck)
Duplicolor floors
33X12.50 4.88's
LC Coils
Winslow
Lumpy
FJORC Officer
Postby Chris » Wed Jun 09, 2010 5:04 pm
Lumpy wrote:Not a bad looking machine there man!!! :band:
Thanks, Lumpy! Figured we'd beat on this one while I do the suspension, brakes and gears/lockers in Blue.
Postby Chris » Fri Jun 18, 2010 10:17 pm
fixed the drag link today and re-connected the knock sensor.. (not sure why it was unplugged.. but, easy fix)
reconnected the tail pipe and cut off the excess pipe. Doesn't sound as ungodly loud as it did.. but it's still makes some noise.
Postby Chris » Mon Jun 21, 2010 2:26 pm
Red went on it's maiden voyage yesterday at HVR. Did pretty well except the power steering started leaking and became stupid difficult to enjoy it any further.
up next, new steering system & a full tune up.
looking forward to next time out.
Postby Chris » Sat Jul 10, 2010 2:05 am
ripped the fenders off.. going to mock up some exo ideas and bang out the dents on the fenders.
steering is wack.. will just upgrade to hi-steer after talking to some folks over at the marlincrawler board.
installed a Downey intake over the last few days.. just for shits and giggles.
Postby Chris » Wed Jul 14, 2010 12:04 am
Next up for Red-
** Hy-Steer kit
** Windshield go bye bye
** 4XInnovation tube doors
Postby Chris » Mon Jul 26, 2010 8:53 pm
d'oh.. had to order a high pressure hose for the power steering.
Postby Chris » Tue Aug 17, 2010 9:29 am
bad day for Red yesterday.. First the battery went completely south which I was expecting.. Then I couldn't get it into low range for the life of me..
With the battery kaput I went down to Auto Zone to get a cheap battery.. I toss an old (so I thought) Duralast on the counter I had for a core and asked for a cheap new battery.. The dude looked at me, then the battery, then back at me..
"Did you buy this new?"
Turns out it was still under warranty. I didn't even think about it. Replaced for free so this was a good point of the story. I ALMOST took this battery in for a core replacement one other time too. Lucky on that one.
:band:
Fast forward to this AM. Went to figure out why it wouldn't go into 4 low. All 6 bolts were loose for the t/c.. d'oh! They were loose enough that when I pulled the lever back the t/c moved slightly (I could finally see this after removing the dust cover). Course I did this in a pair of shorts and flip flops.. cause I didn't really plan on fixing it. :lol:
Fixed that and STILL wouldn't go in. OK, enough...
BFH to the rescue!!
The truck now shifts more smoothly than before the hammer shot.. :lol:
Ah, Toyota.. What won't fix itself can be cured with a BFH.
Oh, and the grill has been removed. One step closer to me actually cutting the roof off and chopping up the cab.
Postby Chris » Tue Aug 17, 2010 9:31 am
Chris wrote:d'oh.. had to order a high pressure hose for the power steering.
and it ended up not being the right part. Rock Auto for the loss.
Autozone is supposed to have one tomorrow for me. Hopefully it's the right one as my arms are getting tired of no PS.
Next
Return to Blast from the Past
Users browsing this forum: No registered users and 0 guests
cron
