Celica All-Trac 'OG'
Postby Admin » Sat Apr 24, 2010 10:02 am
Celica All-Trac ST185
GEN III 3S-GTE, ST205 spec
^^ circa 2002
The Toyota Celica. The car that holds more special moments and meanings to me than any other machine out there.. This is a thread about my first All-Trac Celica. The car that started it all for me.. from the tuning craze, to rally, to blowing stuff up..
It is currently being fitted with a GEN 3 motor out of an ST205 GT-Four. I will be utilizing most of the ST205 drivetrain from the potent motor with water-to-air intercooler and gen 3 turbo.. to the transmission to rear differential and front and rear brake setup.
Parts List:
GEN III 3S-GTE ('94 spec)
ST205 Water-to-Air Intercooler
** ARC intercooler with integrated bov **
ST205 gearbox w/ cooler
Exedy Hyper SIngle clutch/fw
INFINI Avance ECU
Volk CV-Pro (euro), 17x8, +35)
Momo Veloce 325mm steering wheel
** Fiber Images - Carbon Fiber RC hood **
DMS 40mm coilovers
Whiteline Front & Rear Strut Tower Bar
Whiteline Rear Adj. Sway Bar
Admin
Site Admin
Re: Celica All-Trac / ST185 #1 / 'OG'
Postby Chris » Sun Jan 16, 2011 2:19 pm
ok, finally getting some plans together to get this moving again. I've reached out to my GT-FOUR club members for their expertise in getting this sorted.
Postby Chris » Sun Jan 16, 2011 2:34 pm
mr. Wolf. I would like to thank you for your help in advance!
Most of the forum members are my "current project" friends. It is with great pleasure that I have you here to help sort out my junk!
To everyone else reading- Wolf is a long time friend and GTFOUR club member. :horse: If it weren't for the generosity of GTFOUR club members like Wolf, Ivan (Saffo), Dennis , etc.. I wouldn't be where I am today.
Postby Wolf_Tm » Sun Jan 16, 2011 3:07 pm
Chris wrote:mr. Wolf. I would like to thank you for your help in advance!
Too kind mate!
Just gave you little advices based on my little experience... and it's always a pleasure when I have time to... :)
Anyway, as I am 99% of the times on my mobile, if you need anything better to contact me via FB... ;)
Wolf_Tm
TM 250 enduro 2 stroke
GT-four ST205 Snowy White with selfmade 3SGTE v4.1 - [2.34kg/bhp DynoDynamics]
http://www.youtube.com/user/WolfTm250
http://www.facebook.com/people/Wolf-Tm/1457131779
Wolf_Tm
3S-GTE
Postby Chris » Sun Jan 16, 2011 3:21 pm
You are very modest. And that is another reason why I look to you for help.
Feel free to share your 3S-GTE builds and pictures or just link to facebook. There aren't many that specialize in 3SGTE like you imo. :)
Postby Wolf_Tm » Sun Jan 16, 2011 3:35 pm
Chris wrote:You are very modest. And that is another reason why I look to you for help.
That's because my friends have 3SGTEs! :D
Yes, I put all I have on FB, so anything is there... except my car's engine... :D
Wolf_Tm
Wolf_Tm
3S-GTE
and if all goes according to plan...
Postby Chris » Tue Mar 29, 2011 10:01 pm
the old girl should be home this weekend..
Postby Chris » Sun Apr 03, 2011 7:12 pm
And now the fun begins...
Still need to pick up some add'l parts and such but should have mostly everything I need at this point. Going to utilize the gen 3 CT26 for now until I decide what I want to do about ECU tuning. I'll use stock GEN 3 ECU or the IA ECU.
old spec
Postby Chris » Sun Mar 08, 2015 8:25 pm
Parts List:
* GEN III 3S-GTE, ’94 spec
* ST205 Water-to-Air Intercooler
* ST205 Drivetrain with rear subframe from ST205 including (Rear Brakes & Rear diff w/ Torsen type LSD)
* Exedy Hyper SIngle clutch/fw
* ACPT Carbon Fiber Driveshaft (6.25 kg!)
* INFINI Avance ECU (searching for another ECU)
* Blitz NUR Spec Exhaust
* 3″ Front Pipe
* Volk C-Ultra, 17×8, +34
* (Volk CV-Pro (euro), 17×8, +35)
* Michelin Pilot Sport, 245/40
* Momo Veloce 325mm steering wheel
* Fiber Images – Carbon Fiber RC hood
* ST205 Gear Box Cooler
Currently Fitted:
* DMS 40mm coilovers (custom spec Double Progressive springs)
* Whiteline Front & Rear Strut Tower Bar
* Whiteline Rear Adj. Sway Bar*
To Do List:
* Install Gen 3, 3S-GTE
* Modify Harness
* Install Exedy Hyper Single Clutch/Flywheel
* Install Braided SS Clutch Line
* Install new seals (rear main) and belts
* Install WTA Heat Exchanger, Pump and Lines/Wiring
* Swap Toyota Alternator & Starter to gen 3 Engine
* Install ST205 Gear box cooler
* Install Blitz NUR Spec Exhuast and Front Pipe
* Install Toyota Fuel Pump (gen 3)
* Install Toyota OE Fuel Lines
* Install Rear Subframe (ST205 Spec)
~ST205 Rear Brakes & LSD
* Install ACPT Carbon Fiber driveshaft
* Install solid rear diff mount
* Install 17×8 Volk C-Ultra w/ Michelin Pilot Sport 245/40
* Set & Adjust suspension for new wheels/tires
* Install Momo Steering wheel
* Install Fiber Images RC hood
Return to Car
Users browsing this forum: No registered users and 2 guests
