Strict Standards: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead in /homepages/17/d101900905/htdocs/illtuned/forum/viewtopic.php on line 988
Strict Standards: getdate(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead in /homepages/17/d101900905/htdocs/illtuned/forum/viewtopic.php on line 988
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4284: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4286: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4287: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4288: Cannot modify header information - headers already sent by (output started at /viewtopic.php:988)
illtuned.com / FJORC.org • View topic - FJ Cruiser / GSJ15 / 'mini tank'
Postby Admin » Sat Apr 24, 2010 10:07 am
2008 Sandstorm FJ Cruiser (GSJ15)
( ^^ in this pic - BajaRack, LightForce 170 Striker and Toyota Off-Road pkg. wheels on Yokohama 33" Geolander M/T+)
Image Image
Image Image
Special thanks to Yokohama, BajaRack, Man-A-Fre, LightForce & BudBuilt!
Exterior Armor
* BudBuilt 5 pc. Skid Plate Set
* BudBuilt Rear Diff Armor! (SS)*
* Toyota OE Rock Rails --> 4+Plus (MAF) Rock Sliders*
* 4+Plus Rear Lower Shock Skid
* Expedition One Front Bumper
* Kaymar Dual Pivot Tow Bumper
Drivetrain & Traction Aids
* ARB Air Locker (Front, RD111)
* Toyota OE Rear Differential E-Locker
* Toyota Active Traction (A-Trac)
* Nitro 4.88 gears
Suspension
* OME 886/896 (front/rear springs)
* OME Nitrochargers N140 (Front)
* OME Long Travel Remote (LTR) (Rear)
**Long Travel Man-A-Fre Setup**
* 4+Plus Front Upper Control Arms
* 4+Plus High Angle Super HD Rear Lower Control Arms
* 4+Plus High Angle Super HD Rear Upper Control Arms
* 4+Plus High Angle Super HD Panhard Bar
* 4+Plus Extended Brake Lines
Wheel & Tire
* (TRD) Trail Teams wheels, Matte Black 16x7.5
* Yokohama 315/75-16 (35") Geolandar M/T +
* SpiderTrax 1.25" wheel spacers
Lighting
* LightForce Striker 170 mounted to the front bumper
* SilverStar Ultra head lights replacement lamps
Interior
* ARB Freezer / Fridge ("jr.")
* Belkin 300w Power Inverter
* Toyota OE Psg. armrest
* Toyota OE Cargo nets
* Toyota 5 pc. All-Weather mats
* ScanGauge II with XGauge
* MPAC / Springtail Solutions Side Rack
* MPAC / Springtail Solutions Rear Rack
* MPAC / Springtail Solutions Velcro Med Pack
* Various MOLLE & ALICE Bags
Trail Gear
* Superwinch EPi9000 (Amsteel Blue Syn. Line)
* Superwinch Aluminum Hawse fairlead
* Hi-Lift (custom 46") Jack, ORK, ORB, Wabfab adapter & Daystar Isolator
* Tow Straps & D-Shackles
* ARB EZ Tire Deflator
* ARB High Output Air Compressor
* Superflow MV50 Air Compressor (backup)
* Cobra 75, Firestik and Bandi Mount
* BajaRack w/ Hi-lift, Shovel/ax and light mounts
* BajaRack Ladder*
* Powertank 10# CO2 tank w/ adj. regulator
* Staun Tyre Deflators
* ARB Tire Inflator Kit
Miscellaneous
* Safari Snorkel (#415 for Off-Road Pkg. FJ)
* OE Fender flares removed
* Modified OEM Tailpipe ;)
* Toyota 4WD Magazine
* Overland Journal
* Military S-502 custom 'Expedition Trailer' featuring:
Full ac & heat with power inversion - BajaRack Expedition Rack with LightForce - 140 Striker Lights - Camping Lab RTT (roof top tent), Camping Lab Awning with two rooms (changing and rest - Pelican 0350 Cube for extra trail gear.
Wish List
Admin
Site Admin
Hillsville - Sand Dunes
Postby Chris » Tue Apr 27, 2010 10:36 pm
User avatar
Chris
El Presidente
Hillsville - Shehan's Trail & Misc.
Postby Chris » Tue Apr 27, 2010 11:56 pm
User avatar
Chris
El Presidente
bearing, starter, flares and more!
Postby Chris » Wed May 12, 2010 12:23 am
FJ is up on the rack waiting for a wheel bearing.. first one that has went sent new. Can't complain. The starter is def. going to need a good cleaning again.. may be time to replace in the near future.
The OE fender flares finally "fell off"..
Rock Crawler wheel (extra one I bought earlier this year) is being test fit.. looks great but will need to shave the caliper if I'm going to use them without a spacer. Just needs a few mm. I really love a white wheel on the FJC. I still may get a set of these dedicated to the FJ.. I originally bought six of them for the FJ, but then bought the Hilux and figured I may as well use them on it.. Now they have found there way on the 80 series..
Hrmm.. what I should do it rock some 37's on an extra set of wheels and share them with the FJ from time to time..
8-) Ah, common bolt patters are great... I never have to buy a set of tires for any one vehicle! :slap:
User avatar
Chris
El Presidente
Re: FJ Cruiser / GSJ15 / 'mini tank'
Postby Chris » Tue Jun 01, 2010 10:44 am
Sale on Rock Crawler wheels.. I just may pick up a few more and put them on the FJ...
If anyone is looking for steel wheels- the price is good right now.
User avatar
Chris
El Presidente
Postby Chris » Tue Jun 08, 2010 4:51 am
money pit goodness.. ^
User avatar
Chris
El Presidente
Postby HyperBuzzin » Tue Jun 08, 2010 9:43 am
There ya go, Chris!!
A LOT more water out there than the last time I was there with ya!!
Hyperbuzzin..... „ɹǝʇʇods ʎɯ ǝɯɐןq ˙˙˙˙sıɥʇ pɐǝɹ uɐɔ noʎ ɟı„
His: '04 Jeep TJ Unlimited: 2.25"BB--Super Swampers-- BDS Disco's
Hers: '06 Jeep KJ: Stock (for now?)
Also for on the trails, '01 KLX 300R
And also for the street, '99 Vulcan 750
User avatar
HyperBuzzin
FJORC Officer
videos
Postby Chris » Tue Jun 08, 2010 6:38 pm
Ryan... testing his ability to not drop himself and his camera into the muddy waters... Hey, someone has to get the footage..
User avatar
Chris
El Presidente
Postby Chris » Thu Jul 29, 2010 12:04 am
fixed the belt and pulley and then watched my power steering pump fail..........
rebuild kit will be here in a few days.. silly ps pump seal..
User avatar
Chris
El Presidente
Postby Chris » Tue Aug 17, 2010 9:32 am
Ended up getting a used Power Steering pump as well. Figure I'll throw it on and keep the other one for a spare.
Going to fix it soon and also finally install the MAF rock rails for Rausch creek I4WDTA training fun.
User avatar
Chris
El Presidente
Next
Return to Truck
Who is online
Users browsing this forum: No registered users and 2 guests
cron
